[EICMA][NEW] Bimota
Sujet : [EICMA][NEW] Bimota
jeu. 15 nov. 12 09:12
Back when stock superbikes had stonking engines and shitty frames, Bimota created a neat little business for itself, housing those engines in good frames. But, when bikes started including handling as stock, the tiny Italian company fell on hard times. It tried some weird suspension, it made some Ducatis a little more special. Then, this year at EICMA, they rented a stand twice the normal size and showed up with 19 models. Wow.
Some of those models are, of course, things we seen before. There’s the 1198-engined DB8, the DB10 riff on the old, air-cooled Hypermotard theme and the hub-steered Tesi of course (now with cleaned-up looks), but now there’s a DB11 too, powered by the Testastreta 11 motor that’s in the Diavel and Multistrada. A Bimota with long service intervals, imagine that. Just in case you were worried Bimota had turned practical, they bolted a supercharger to one for 188bhp and called it the “VLX.”
What if you’re a Bimota enthusiast that wants to ride off road? They fitted spoked wheels to a DB10 and called it the DBX.
New too is the BB2 concept, which re-styles an S1000RR and an interesting take on the Multistrada, basically fitting the DB11 with flat bars and a really big fairing, plus design from the same firm that penned the BB2: sak_art design.
Unless you’re a wealthy bike collector with oddball taste, this is really just an opportunity to oggle how good steel trellis frames and swingarms look when combined with carbon fiber, minimal fairings and some lowercase Bs.
Une galerie photo présentant d'autres modèles est disponible également ici ==> http://hellforleathermagazine.com/2012/ ... /?gal=1#/0
On trouve notamment le BB2 Concept:
This new Bimota BB2 houses the 193bhp engine from an S1000RR in a new, aluminum spar chassis. But it’s not the (likely) sharper geometry or (likely) lower weight or even that machined-from-billet aluminum subframe that catches our eye, it’s the use of a retro single square headlight. Damn that looks good.
For a Bimota, there really doesn’t appear to be any weirdness here. Conventional frame, conventional forks. Instead, it largely appears to be a design exercise from Tuscan firm sak_art design. The large side and front fairings are reminiscent of ’80s Bimotas, particular in the flow of plastic from side to tank, while the rear is more modern in its abrupt dimensions, but references those old bikes in its blockiness.
In fact, looking at these new photos, it’s evident the BB2 retains the S1000RR’s frame, triple clamp and swingarm, making this largely a styling exercise. Look closely at the photos and you’ll see the BMW swingarm pivot, swingarm, top clamp and even clocks, albeit with a new fascia bearing the “BB2″ name.
Perhaps tellingly, BMW itself refers to the bike you see here as “An initial concept of this new motorcycle.” Is there more to come?
Et une autre série de photos ==> http://hellforleathermagazine.com/2012/ ... /?gal=1#/0
Source
Sujet : Re: [EICMA][NEW] Bimota
jeu. 15 nov. 12 09:23
Useless
jeu. 15 nov. 12 09:24
Oui, des motos à prix d'or construites sur des moteurs de modèles déjà existants.
Réservés aux collectionneurs et aux die-hard fans.
jeu. 15 nov. 12 09:25
Et avec un look des années 80...
jeu. 15 nov. 12 09:26
La DB11, pas trop.
Par contre, le concept fait effectivement références aux anciennes Bimota.
jeu. 15 nov. 12 10:25
C'est marrant une moto qui fait dépassée au niveau esthétique alors qu'elle n'est pas encore commercialisée !
jeu. 15 nov. 12 11:19
avec le moteur de la s1000rr elle va levé a toutes les sortie de courbes
jeu. 15 nov. 12 17:20
il y a du mélange de style
Labriche
ven. 16 nov. 12 18:52
Elle va surement plaire au allemand.
