Qui serait intéressé par une commande groupée de boitier DimSport Rapid Bike pour Panigale ?
http://web.dimsport.com/rapidbike/news. ... ge=1news=1
Rapid Bike Technology brings out the best of DUCATI 1199 PANIGALE
RAPID BIKE technical dept has spent quite an intensive development session on the factory power bench together with extensive test on the race track in order to offer a number of engine mappings matching 3 possible configurations of the well-known DUCATI 1199 PANIGALE:
STOCK BIKE
The Ducati 1199 Panigale is showing just few horsepower more than 160 hp at the wheel. Using a specific injection map for each cylinder thanks to the RB EVO add-on module the bike shows a consistent gain at the mid range (dyno graph 1), this result is further improved using the RB RACING module (dyno graph 2) which combines a new injection and ignition map to reach a considerable change of the bikes engine power delivery.
STOCK BIKE equipped with Termignoni full exhaust system
Installing the after-market exhaust complete system by TERMIGNONI allows a power gain of at least 3 hp, this helps even more the overall bike performance reaching its top thanks to Rapid Bike EVO and RACING add-on modules. In particular, the RACING add-on module shows an outstanding result of 181,5 hp at the wheel (dyno graph 3)
Upload of stock ECU + Termignoni full exhaust system
The combination of Termignoni exhaust system and upload of the stock ECU allows an overall improvements of the engine top power. However, the bike continues to reach the best performance thanks to Rapid Bike add-on modules, maintaining the top result of 181,5 hp at the wheel with specific injection and ignition maps developed specifically for this bike version.
TECHNICAL PREMISE: All measurements and dyno graphs are recorded on the factory power bench equipped with a dynamic airflow management system, and are strictly related to the specific climatic conditions experienced during our tests.
DYNO GRAPHS SYMBOLS
map_evo = using the EVO add-on module with a specific injection map per cylinder and dynamic management of both lambda sensors
map_racing = using the RACING add-on module which combines the EVO injection map together with a specific ignition map
== Remise possible jusqu'à -20% suivant la quantité.
Liste pseudo (sérieusement intéressé) :
Les discussions ici ======== Boîtier Dim Sport Rapid Bike
