SF full carbone de Shifttech
chocorem
Sujet : SF full carbone de Shifttech
mer. 19 janv. 11 01:27
bon la ya un peu de carbone .....
c'est la version shifttech a 44 k$
GP Brembo Brake Master
GP Brembo Clutch Master
Moto Corse Billet Brake Clutch Reserviors
Brake Tech Ceramic/Carbon Front Rotor
Lightweight Wave Rear Rotor
Ohlins RT Front Forks
Ohlins TTX Rear Shock
BST Carbon Fiber Wheels
CF Belly Pan
CF Fuel Tank
CF Tail Section
CF Pillion Cover
Custom Seat
CF Fuel Cap
CF Key Guard
Ohlins Titanium Steering Damper
HID Light Kit
Lightweight Li Performance Battery
CF Lower Tank Panels
CF Hugger
CF Swingarm Cover
CF Chain Guard
CF Sprocket Cover
CF Waterpump Cover
Black Silicone Coolant Hose Kit
CF RL Engine Case Covers
Aluminum Radiator Guards
Yoyodyne Clutch Slave Cyl
Sutter GP Performance Slipper Clutch
CF Clutch Cover
Custom Rearsets W/Titanium Hardware
Quickshifter
Microtec ECU
CF Headlight Mask
CF Upper Gauge Cover
Frame Painted Custom Black Metalic (House of Kolor)
DID Gold Chain
Supersprox Rear Sprocket
Black Aluminum Axle Nuts
Aluminum Front Axle
Titanium Bolt Kit- 95% Of All Bolts Are Titanium
Titanium Ride Height Bar NCR
Billet Corsa Oversized Velocity Stacks
CF Oversized Custom 1098 Airbox With CF Air Intakes
Black Powder coated Handlebar
CF Custom Tail Tidy
CF Tail Section With Undertray
Titanium Zard Exhaust
Black Headlight Housing/No Turnsignal Holes
LED Tail Light
Bimota Kickstand Black
Gilles Frame Sliders
CF Radiator Side Guards
CRG Bar End Mirrors
Black Valve Covers
High Compression Pistons
New 1198cc Cylinders
Custom Lightened, Balanced Blueprinted Crank Shaft
Light weight Flywheel
All New Bearings/Seals/Gaskets
New Valves Camshafts
Ported Cylinder Heads
Sujet : Re: SF full carbone de Shifttech
mer. 19 janv. 11 01:31
Ca c'est de la bête , magnifique , j'adore :bravo2: :bravo2:
mer. 19 janv. 11 01:32
Tu n'as pas une photo de plus près
mer. 19 janv. 11 01:34
Voila la liste :x
chocorem
mer. 19 janv. 11 01:45
mer. 19 janv. 11 01:50
C'est les cas de le dire : il y a du LOURD !
mer. 19 janv. 11 01:52
Pour le coup l'amortisseur de direction Ohlins fait pauvre :lol:
mer. 19 janv. 11 01:57
Merci , chocorem , il y a encore du taf pour quelle soit comme ça :mur: :mur:
mer. 19 janv. 11 03:07
la geuele, et le moulin, manque plus qu'un vrai pot :griendit: :griendit: :griendit:
mer. 19 janv. 11 03:18
Mise a part les entrées d'air forcée et le sabot que je n'aime pas :no:
Elle est à tomber :x :x :x :x
chocorem
mer. 19 janv. 11 03:20
Moi j'adore les entrées d'air ...... elles vont bien avec la ligne ! Par contre le sabot, suis d'accord avec toi !
mer. 19 janv. 11 03:22
avec les entrées la, tu gagne de vrai chx, je suis sur que ces des modèles de sbk qu'ils ont découpé.
chocorem
mer. 19 janv. 11 03:29
tontongiorgio87 a écrit :avec les entrées la, tu gagne de vrai chx, je suis sur que ces des modèles de sbk qu'ils ont découpé.
Encore une fois, pour gagner des CVs, il faut un ensemble cohérent .... si tu touches a l'admission, il faut toucher aux temps d'injection ... puis a l'echappement
Ensuite, comme la plage de temps est limitée, il faut augmenter soit la pression d'essence, soit le diamètre des injecteurs et bien sur a chaque fois compenser dans l'ECU !
Augmenter l'admission d'air toute seule, aura comme effet de te faire tourner trop pauvre et de te faire des trous dans les pistons ..... (enfin peut être après les soupapes ! :griendit: :griendit: :griendit: )
J'ai un piston qui traine encore avec de jolis trou dedans suite a une trop forte "optimisation" que j'avais essayer de faire au banc .... (voiture pas SF)
mer. 19 janv. 11 03:33
heureusement que t'été la, je suis pas tomber de la dernière pluie, quoi que, pour mettre brûlé au 1er degrés tout a l'heure en mettant la housse sur ma mob, je me pose des questions.
mer. 19 janv. 11 03:37
:griendit: :griendit: :griendit: j'ai percé 7 pistons :!: :o :shock: :shock: sur mon 50 MTX avec kit polini 65 , pot de détente malossi et carbu dell orto 21 :heart: 8)
:scratch: ça vient peut étre de là , alors :roll:
oui , je sais :hs:
mer. 19 janv. 11 03:39
c'été la belle époque criky!
chocorem
mer. 19 janv. 11 03:40
cricky16 a écrit : :griendit: :griendit: :griendit: j'ai percé 7 pistons :!: :o :shock: :shock: sur mon 50 MTX avec kit polini 65 , pot de détente malossi et carbu dell orto 21 :heart: 8)
oui , je sais :hs:
Waouh ma jeunesse qui ressort .... Combien de transfert le Kit polini :rofl:
street74
mer. 19 janv. 11 04:14
Marco, tu peux avoir ces fameuses protections de cadres de chez Gille Tooling?
Trop top :pouce: :pouce::pouce::pouce: :pouce: :pouce: :pouce::pouce::pouce: :pouce:
mer. 19 janv. 11 04:30
Sujet créé. Merci de rester la discussion initiale. :carton:
l'oncle
ven. 21 janv. 11 02:35
fantastique machine, mais j'te dis le prix de la taxe carbone... combien ca pèse? en grammes bien sûr!
ricobab
ven. 21 janv. 11 03:25
Je la prend, ne serai ce que pour les jantes et la prépa moteur.
Le reste, tout en carbone est une question de gout.
ven. 21 janv. 11 03:39
y avait une sf s rouge super préparer, je suis plus dans quel pays mais, elle avait un fourche comme la desmocedici.... en vente sur ebay d'ailleur a une époque. sa vous dit un truc?
L'tom.com
lun. 24 janv. 11 20:49
Jolie vitrine :mr: :mr:
JB EH
lun. 24 janv. 11 21:24
Elle est vraiment magnifique!!!!!!!!!!!!!!!c'est d'un grande beauté!!!!!!! :pouce: :pouce::pouce::pouce: :pouce: :pouce: :pouce::pouce::pouce: :pouce:
ven. 28 janv. 11 18:23
superbe machine mais je n'aime pas trop les entrées d'air, le sabot et surtout les pots..... :no: :no:
le reste .......que dire :heart: :heart:
ven. 28 janv. 11 18:28
Le réservoir est superbe. Belle pièce techniquement parlant !
chocorem
ven. 28 janv. 11 19:14
Le reservoir et le Cul carbone me titillent !!!!!!
sam. 29 janv. 11 00:05
je la trouve vraiment très belle, mais trop de carbone, tue le carbone....
JB EH
sam. 29 janv. 11 00:44
Foes man a écrit :je la trouve vraiment très belle, mais trop de carbone, tue le carbone....
Ben voila je pense la même chose!!!!!! :pouce: :pouce::pouce::pouce: :pouce: :pouce: :pouce::pouce::pouce: :pouce:
sam. 29 janv. 11 01:02
Pas moi ;)
Revenir à « Photos »
