[NEW] Nouvelle version de la Panigale R ou de la Standard en préparation ?
Sujet : [NEW] Nouvelle version de la Panigale R ou de la Standard en préparation ?
jeu. 31 juil. 14 11:20
Look at what we spied this past Monday, July 28th – it’s the new 2015 Ducati 1199 Panigale R leaving one of Ducati’s European facilities.
As you can see, the Ducati engineer who was riding the bike wasn’t too happy with the photographer. He wagged his finger once, made eye contact, and then throttled down to avoid more photos. Too slow, Junior, maybe next time.
We’d seen photos of the bare-skin, carbon-fiber Ducati earlier this year and spent some time speculating on exactly which model it would be. It appears, but of course it’s not confirmed, that this is the 2015 R.
Body/Suspension
Unfortunately we can only make estimates on the visual appearance of the bike and limited on technical specs. The only technical thing we can decipher is the front suspension. The Öhlins forks are ditched for a set of Marzocchi front forks. Which comes as no surprise as other Ducati models already made this switch – as the Monster features 43mm Marzocchi forks and the 1199 Panigale (base model) features 50mm Marzocchi forks. We’d assume the rear suspension has also been swapped for Marzocchi as well. Would this bring the price down?
Want to know what won’t bring price down, those weight saving carbon-fiber fairings. Earlier spy photos we’ve seen show the bike MIGHT feature a full carbon-fiber body and an aluminum tank, so we’ll have to see. That said, the Panigale is already the lightest bike in the Ducati fleet at 417 pounds wet.
The photographer suggested the wheels and tank are updated, but from what we can tell, they don’t appear to be any different than what’s on the 2014, for the R model that is.
Exhaust
Don’t worry, those dual exhaust cans probably won’t make production. It looks to be a shoddy bracket made from a vice temporarily mounting the slip-on pipes. The device behind the rider’s heel hints at emissions or noise testing, although one of our emissions experts said they’d never seen an analysis device that small, but hell, it is Italy…
The rear carbon-fiber piece that covers the exhaust loop under the seat, looks to be smaller and have a different shape than last year’s model.
As the 2014 model had some slight power changes over 2013, we’re anxious to see if this model will too. Also, the 2013 model was roughly $1,000 cheaper than the 2014, so we’re going have to wait and see if the price goes up as well.
http://rideapart.com/2014/07/spied-duca ... anigale-r/
bugsy
Sujet : Re: [NEW] Nouvelle version de la Panigale R ou de la Standard en préparation ?
jeu. 31 juil. 14 11:56
J'aime bien le pot :silent:
jeu. 31 juil. 14 12:42
j'avais entendu parler de cette "rumeur" de refonte de la panini...
emmademars
jeu. 31 juil. 14 14:18
D'après les sources d'un DS, il y aura bien une refonte en 2015...
jeu. 31 juil. 14 14:20
Déjà, étonnant voir suspect......
ven. 1 août 14 00:05
En même temps, niveau timing ça se tiendrai si on compare aux derniers modèle de la marque :
Diavel, lancé début 2011 = refonte en 2014
Monster 1100 / EVO / 1200 : 3 à 4 ans entre chaque
Panigale, lancé début 2012 = refonte en 2015 ?
Même si là sur la photo, y'as pas l'air d'avoir des masses de différence ...
Au sujet de ce passage :
Je sais pas qui sont leurs "experts" :lol: , mais il s'agit clairement d'un servomoteur de valve à l'échappement avec son câble, le même que sur le modèle actuel en fait, monté à l'arrache pour l'essai. Et en aucun cas d'un quelconque instrument de mesure...
levraiEagle4
dim. 3 août 14 14:31
Neo14 a écrit :Déjà, étonnant voir suspect......
Ben vu tous les soucis liés à la chaleur avec les carénages qui brulent sur les routières et sur les pistardes avec en plus les soucis avec les bacs à huile. Les silencieux qui finissent par se fissurer à force de chauffer. Il y a un gros travail quant à l'amélioration des échappements.
rambo33
mar. 5 août 14 18:51
dans desmo ils évoquent une panigale 1299...
mar. 5 août 14 19:13
:shock: si ils font ça, c'est n'imp!ca sent le buzz :griendit:
On dirais qu'il teste une ligne d'échappement pour le SF 1199 :griendit:
Funky
mar. 5 août 14 21:26
Souvenez-vous :
2007 commercialisation de la SBK 1098
2009 évolution en 1198
2012 remplacement de la 1198 par la Panigale
Il ne serait donc pas étonnant de voir apparaître une phase 2 de la Panigale en 2015, puis une remplaçante en 2017/2018.
mer. 6 août 14 00:35
Tout à fait Funky, comme je le disais plus haut au sujet d'autres modèles, ~ 3 ans avant des évolutions, c'est ce qu'on observe depuis une dizaine d'année...
darckaxel
mer. 6 août 14 00:52
Les pots sur le côté me font pensais à un roadster (comme une certaine SF) .La fourche avant est une marchesini je pense. Pourvue qu'il développe la base d'une future streetfighter.
mer. 6 août 14 03:45
Les pots sur le côté sont là pour effectuer des tests, rien de plus. En aucun cas cela débouche systématiquement sur un modèle définitif.
Surement des essais vis-à-vis des problèmes qu'évoquait levraiEagle4 d'ailleurs, ainsi que vis-à-vis des évolutions des normes anti-tout à venir. Suffit de voir la taille de la chambre de stabilisation de gaz, là où sont d'habitude logés les silencieux.
Tombert
Votre Ducati : 748 Biposto
mer. 17 sept. 14 15:18
La Ducati 1299 Panigale officialisée par accident !
Prise de cylindrée pour la Ducati Panigale en 2015 ©DR
Galerie photos (1)
Si l'on sait depuis bien longtemps que Ducati aura un Scrambler au catalogue en 2015, on savait moins que le constructeur Bolonais allait proposer une 1299 Panigale !
Et c'est cette photo prise lors de la convention des revendeurs américains qui dévoile cette information. En effet, Ducati serait sur le point de remplacer, ou plutôt faire évoluer, sa Superbike en la faisant passer de 1 199 cm3 à 1 299 cm3.
Ainsi, le L-Twin Superquadro devrait prendre 10 chevaux supplémentaires grâce à l'augmentation de sa cylindrée, ainsi qu'une bonne louche de couple. Elle devrait donc venir tutoyer les 200 chevaux en version full et sera probablement proposée, dans un premier temps en version base et S, et dans un second temps, en version R.
L'officialisation devrait se faire à Milan.
via visordown.com
Galerie photos (1)
Arnaudu64
jeu. 18 sept. 14 11:02
Et oui, Ducati va nous resservir sa "recette" des 1098/1198 avec les 1199/1299 pour 2015 !!
et oui, tous les 3 ans, on fait évoluer avec 100 cm3 de plus et encore 10 chevaux !!!
elle devrait être dévoilée officiellement au salon de Milan le 6 novembre prochain !
Avec 210 canassons, ça va commencer à envoyer un peu le pâté !!!
Espérons que ce gain de cylindrée lui permettra de gagner enfin une course en WSBK !!
Il s'agirait d'une "bourde" d'un concessionnaire Américain :
http://www.moto-station.com/article8542 ... caine.html
jeu. 18 sept. 14 11:10
La suite ICI pour parler de cette "nouveauté". ;)
Sethofbodom
jeu. 18 sept. 14 14:50
Arnaudu64 a écrit :Et oui, Ducati va nous resservir sa "recette" des 1098/1198 avec les 1199/1299 pour 2015 !!
à ce rythme là dans 10 ans on se retrouve avec une 1502 / 1602 panigale ! ^^
