Carbone ou Standard : Caractéristiques et couleurs
Documentation officielle... (Diavel et accessoires), comparatif avec les autres motos... Vos avis, vos essais, la presse... etc.
Sujet : Carbone ou Standard : Caractéristiques et couleurs
jeu. 4 nov. 10 16:48
Chassis
Frame Tubular steel Trellis frame
Wheelbase1590mm (62.6in)
Rake28°
Front suspension Marzocchi DLC coated 50mm fully adjustable usd forks
Front wheel travel120mm (4.7in)
Front whee lMarchesini forged and machined 9-spoke 3.50 x 17 (Carbone) OU 14-spoke in light alloy 3.50 x 17 (Standard)
Front Tyre120/70 ZR 17 Pirelli Diablo Rosso II
Rear suspension Progressive linkage with fully adjustable Sachs monoshock. Aluminium single-sided swingarm
Rear wheel travel 120mm (4.7in)
Rear wheel Marchesini forged and machined 9-spoke 8.00 x 17 (Carbone) OU 14-spoke in light alloy 8.00 x 17 (Standard)
Rear tyre 240/45 ZR17 Pirelli Diablo Rosso II
Front brake 2 x 320mm semi-floating discs, radially mounted Monobloc Brembo callipers, 4-piston with ABS
Rear brake 265mm disc, 2-piston floating calliper with ABS Fuel tank capacity17l - (5.3US gal)
Dry weight 207kg (Carbone) - 210kg (Standard)
Instruments Handlebar mounted instrumentation with LCD display: speed, rpm, time, coolant temp. Warning lights for: Neutral, turn signals, high-beam, rev-limit, DTC intervention, ABS status, oil pressure, fuel reserve. Tank mounted instrumentation with TFT colour display: gear selected, air temp, battery voltage, trips 1 2, fuel reserve trip, average and actual fuel consumption, average speed, trip time, scheduled maintenance. Full status and/or management of Riding Modes, DTC, RbW and ABS
Warranty 2 years unlimited mileage
Body Colour Carbone Red and Matt Carbon (red / black) - Glossy and Matt Carbon - (frame/wheel) (racing black / black)
Body Color Standard Red (red / black) - Pearl White Silk and Metallic Black - (frame/wheel) (black / black)
Versions Dual seat
Seat height 770mm (30.3in)
ABS Standard equipment
DTC Standard equipment
Engine
Type Testastretta 11°, L-Twin cylinder, 4 valve per cylinder, Desmodromic, liquid cooled
Displacement 1198.4cc
Bore x Stroke 106 x 67.9mm
Compression ratio 11,5:1
Power 162hp (119kW) @ 9500rpm
Torque 94lb-ft (127.5Nm) @ 8000rpm
Fuel injection Mitsubishi electronic fuel injection system, Mikuni elliptical throttle bodies with RbW
Exhaust Lightweight 2-1-2 system with catalytic converter and two lambda probes. Twin aluminium mufflers
Transmission
Gearbox 6 speed
Ratio 1=37/15 2=30/17 3=27/20 4=24/22 5=23/24 6=22/25
Primary drive Straight cut gears, ratio 1.84:1
Final drive Front sprocket 15; Rear sprocket 43
Clutch Light action, wet, multiplate clutch with hydraulic control. Self-servo action on drive, slipper action on over-run
Emissions
StandardEuro 3
Sujet : Re: Carbone ou Standard : Caractéristiques et couleurs
lun. 28 févr. 11 23:49
Pour faire patienter les futurs acquéreurs ...
AZRAËL
mar. 1 mars 11 01:20
Tu es passé sur Bordeaux ??
Elles sont superbe , à craquer . Je dois dire que plus je les regardes , plus ils me font envies ........ces Diavel :evil: :evil: Surtout la black !! :heart:
mar. 1 mars 11 01:27
Je vais vous étonner , mais c'est la carbone noire que je préfère
mar. 1 mars 11 01:37
AZRAËL a écrit :Tu es passé sur Bordeaux ??
:griendit: :griendit: :griendit: parcours un peu le forum .... et tu verras ce que je pense de ZONE ROUGE BORDEAUX :!:
AZRAËL
mar. 1 mars 11 01:40
Je viens de lire a l'instant :shock: :shock: OUPSSSS !!! c'est chaud :lol:
mar. 1 mars 11 01:47
martial a écrit :Je vais vous étonner , mais c'est la carbone noire que je préfère
Alors la Martial, tu m'étonnes :rofl: :rofl:
jeeps
mer. 2 mars 11 04:33
Bravo pour les photos, il me semble que je prefere le rouge Ducati ! (désolé!)
l'oncle
mer. 2 mars 11 11:20
les jantes du carbon sont vraiment superbes
ToTo76
mer. 2 mars 11 14:12
Moi je reste sur ma rouge avec surement dans un futur proche après la réception , peinture des écopes et du dessus du phare ... car le gris c'est pas top ...
Revenir à « Présentation, avis, essais et infos (Diavel) »
