KTM Super Duke 1290
- Amour, Gloire et Beauté
Sujet : Re: [NEW] KTM Super Duke 1290
Une Gladius te suffit pour ça, non?
- cricky16
- Ducati-Maniaque d'or
HS on : " Gladianus " est vendu
Elle a d'ailleurs fait un nouveau podium ce week end.
Comme quoi, le pilote n'y peut rien, c'est une véritable machine de compétition
HS off
Place maintenant au roadster pour HOMME
HS off
Attending KTM’s launch of the 2014 KTM 1290 Super Duke R in Spain, or friend Iwan van der Valk from Testmotor.nl has been kind enough to share his thoughts and review regarding Austria’s newest hooligan machine.
Getting a chance to put the KTM 1290 Super Duke R through its paces on the road as well as the track at Ascari, we are supremely jealous of Iwan’s experience. Hopefully KTM USA will let Asphalt & Rubber have a turn on the 1290 Super Duke R soon. – Jensen
For 2014, KTM is launching the third model of the Super Duke line, which they have been selling since 2005 (note: KTM mentions it’s the fourth edition because of the small upgrade in 2011).
The new KTM 1290 Super Duke R has a brand new 1,301 cc v-twin engine, that delivers a huge amount of horsepower (180bhp) and a mountain of torque (106 lbs•ft). The 1290 Super Duke R only weighs 417 lbs dry.
Engine
The previous iterations of the LC8-lump were always hampered with a difficult throttle response. According to KTM, this part-throttle behaviour has been reworked extensively on the KTM 1290 Super Duke R, and we have to agree it does feel fine now, apart from a minimal on-off reaction when you first open the throttle mid-corner.
Overall though, we like the driveability of the ride-by-wire system. The big v-twin sounds amazing and runs so smoothly that you can use a broad RPM range in any gear, although you do need to stay above 4,000 rpm to avoid bucking.
Above that the engine truly is a beast: turn the traction control off and it’s simply impossible to keep the front wheel down in the first 3 gears. In fourth, fifth, or sixth, a tiny crest in the road will result into a power-wheelie. KTM definitely didn’t lie when they christened this bike as ‘The Beast’: the 1290 Super Duke R is faster, stronger, wilder than you can imagine.
It is however geared too long. At freeway speeds in 6th, the engine is lugging along as it sits below 4,000 rpm, and doesn’t feel particularly happy about it. You really don’t need more than 4 gears on public roads unless of course you are addicted to prison speeds. Gearing The Beast shorter however doesn’t seem like a valid solution because of the enormous power that’s available.
Electronics
This is where KTM’s state-of-the-art electronics package, a modern Bosch ABS and traction control system, comes into play. It should be noted that these systems are not the same as the ones on the KTM 1190 Adventure, which means that KTM will not be offering the recently flaunted Bosch MSC stability system on the big Duke.
The ABS system is different from most other sport bikes too, in that it works fine on the street, but on track it seems that you can get the most out of the brakes by disabling the ABS altogether. Even in its sports setting, the ABS system comes in too quickly on track. It’s probably more a gimmick than anything else, but experienced riders can also choose a ‘supermoto’ setting for the ABS, which allows you to slide the rear tire.
The Bosch Traction Control on the other hand is fantastic. The rough asphalt of the Spanish mountain passes didn’t phase the 180 hp / 106 lbs•ft bike at all as the system worked overtime on the broken surface. At first this felt a bit awkward, but soon you gain full-confidence in the electronics.
The system worked just as brilliantly on the Ascari track: we could see the TC light coming on in the 90° left-hander, but we couldn’t feel the system working at all, and the Super Duke R stayed perfectly stable.
The only downside of this electronics package is the irritating way of turning it off and on. You have to push a button for 5 seconds ,while being stationary, which means that you can’t make any changes on-the-fly and react quickly to changing conditions.
KTM says that they have done this for safety reasons, but this doesn’t seem to add up with their ‘ready to race’ image, and the simple fact of introducing a 180 horsepower bike into the market.
Chassis
The Brembo M50 monoblocs already proved themselves on other bikes, like the Ducati 1199 Panigale, and they are no different on the 1290 Super Duke. The braking power is immense, but you get so much feedback and feel from the system that you never lose confidence in the front. You can execute emergency stops on loose surfaces without fear of lowsiding.
The comfortable seating position really adds to this feeling of total control with a great stock seat and a gentle knee-angle to the pegs . Shifting gears is very easy, although we did get a couple of false neutrals on the rough twisting roads, most probably because of the hectic riding conditions and dodgy roads during the test.
The all-new trellis frame is suspended – as always with KTM – by high quality WP elements. The front forks each have separate damping controls, meaning that one leg controls the rebound, while the other one takes care of the compression damping.
All in all, there’s more flex in this chassis than you would encounter on a superbike — this is not a hot rod RC8 without fairings. When riding fast, the bike moves around quite a bit and in these extreme conditions it feels nice to have a steering damper as a fail safe.
The flexibility does take some getting used to, but you definitely gain confidence after a while. On public roads there’s plenty of ground clearance, but on track our toesliders got a good workout. The race-version we tried had much more ground clearance for this exact reason.
The performance of the front end was somewhat hit and miss however. The Dunlop Sportsmart2 tires gave full confidence at one point while lacking grip a little while later. According to KTM no changes were done to the bikes, so we don’t really know why the front-end feedback and grip was so changeable.
The rear suspension is of a beautiful single-sided construction, which always feels stable, tight, confident, and perfectly in control thanks to the traction control system.
Details
The KTM 1290 Super Duke R is a quality product: the fit and finish looks wonderful except for the contrasting cheap looking exhaust system. Of course KTM likes you to solve this issue by buying a full Akrapovic system…very expensive but then again, it promises an extra 12 horses.
The headlight with striking LED daytime running lights is mounted very low on the forks and takes some getting used to visually. It turns on and off automatically and we still feel that the rider should control this but luckily this setup doesn’t flicker as nervously as the Adventure headlight.
Conclusion
Priced at €17,599 in Europe (not pricing is available in the USA yet), the 2014 KTM 1290 Super Duke R is a hell of a lot of money for a naked bike. For that amount we feel that KTM should have thrown in some carbon bits and a better race-ABS system.
But all-in-all this brand new 1290 Super Duke R doesn’t have any real flaws (apart from the MTC and ABS controls). This bike delivers what’s been promised: a insane streetfighter with an obscene amount of power, controlled to be enjoyed to the fullest.
You can ask yourself if all this power is really necessary, but in practice, the huge and addictive wave of torque gives you riding pleasure few bikes can match: powering this beast out of corners feels fantastic, over and over again. It has more power than you’ll ever need or want.
The commanding seating position and the wild ride nicely finish off the concept of this big ballsy naked. Just try to keep your licence, if at all possible.
Source
Je ne sais pas.
J'ai tiqué aussi en voyant le prix.
Peut-être se sont-ils plantés...
- Khallimero
Peut etre en comptant l'akra obligatoire
- Barbatos
Punaise à plus je la vois, a plus je la trouve jolie....
Et le bruit avec les akras en effet....
Ca sent l'essai chez PP 77 dès que possible
Pas cool le prix par contre....
- Khallimero
Bizarre elle a été annoncée à £13999 en AngleterreHermod a écrit :17600 € :/
C'est pas 15,500 :/
- Khallimero
Malgré le transport par bateau pour le UK, ca m'etonnerait qu'elle soit moins chere en France
Vive les taxes, youpi
- cricky16
Tu sais " R one ", on a affaire à des ducatistes
, ils sont contents que quand c'est chère
Prix catalogue 15690€ , le prochain qui dit autre chose, je me ferais un plaisir de l'enrhumer en Wheeling avec le SD
- Khallimero
Clés en main ou faut rajouter les frais d'immat/mise en service ?
Y'a pas des trucs cachés comme les frais de transport depuis l'usine comme chez MV ?
- Khallimero
En meme temps, le orange c'est une couleur low cost, faut pas s'etonner
- cricky16
Khallimero a écrit :Clés en main ou faut rajouter les frais d'immat/mise en service ?
Si si, y'a une taxe spéciale pour les Parigots
